Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Or what is the best way to do captions in vmix live?
I have an upcoming event that will be captioned in another language. Event is live.
Captions will be sent from a powerpoint, and split between a screen onsite above stage and then another output on vga to me.
I was thinking desktop capture, but I would need to crop it so only the small strip of text shows unless there is a way to "alpha channel" on an input?
Running the captions manually is NOT an option - I have to take their output as it is synched to stage action.
Joined: 2/18/2014(UTC) Posts: 1,844 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
When is the event? We are working on adapting an existing hw based technology for that into vMix. It sort of works already, but a few additional needs (like recording the captions) will be adressed. Check out the demo in another topic (second post).
