davidcl
#1 Posted : Sunday, July 18, 2021 11:50:08 PM(UTC)
davidcl
Gabon
Hi all
i dont find how to configure the headphone output on vmix with the Xair?
i find the A to G channel (AUX) but the headphone not?
thanks for your help.
David
andreypetr
#2 Posted : Monday, July 19, 2021 9:39:56 AM(UTC)
andreypetr
What do you mean by headphone output? Most of the time you are sending audio to the main L/R mix which is monitored by default. Go to the settings and open Audio Outputs. Select X-Air ASIO and proper USB audio return channels. Now you should be able to hear audio from vMIX in your headphones.
jip
#3 Posted : Monday, July 19, 2021 10:25:58 PM(UTC)
jip
Estonia
Originally Posted by: davidcl Go to Quoted Post
Hi all
David
With XR18, I have assigned vMix headphone output to two XR18 input channels (x+y). Then in X Air mixer, those channels are selected to the channel strip by changing inputs from mic to usb x and y as a stereo pair. If I wan to monitor vMix through headphones connected to XR18, I just solo those the headphone return channels in X Air.
It's not an entirely straightforward configuration but I hope this helps for your problem.
thanks 1 user thanked jip for this useful post.
davidcl on 7/29/2021(UTC)
