Joined: 12/23/2018(UTC) Posts: 120   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Hi all i dont find how to configure the headphone output on vmix with the Xair? i find the A to G channel (AUX) but the headphone not? thanks for your help. David
Thanks: 4 times Was thanked: 10 time(s) in 10 post(s)
What do you mean by headphone output? Most of the time you are sending audio to the main L/R mix which is monitored by default. Go to the settings and open Audio Outputs. Select X-Air ASIO and proper USB audio return channels. Now you should be able to hear audio from vMIX in your headphones.
Joined: 7/23/2013(UTC) Posts: 136  Location: North Thanks: 14 times Was thanked: 13 time(s) in 11 post(s)
Originally Posted by: davidcl  Hi all i dont find how to configure the headphone output on vmix with the Xair? i find the A to G channel (AUX) but the headphone not? thanks for your help. David With XR18, I have assigned vMix headphone output to two XR18 input channels (x+y). Then in X Air mixer, those channels are selected to the channel strip by changing inputs from mic to usb x and y as a stereo pair. If I wan to monitor vMix through headphones connected to XR18, I just solo those the headphone return channels in X Air. It's not an entirely straightforward configuration but I hope this helps for your problem.
 1 user thanked jip for this useful post.
