Invexabi
#1 Posted : Thursday, July 8, 2021 3:45:08 PM(UTC)
Invexabi
hi there.....
I'm having trouble using the internal camera, all camera sources will get a notice Capture Resolution is not support by this Device...can anyone help me?...
The camera works normally when I use it on OBS or Zoom
My laptop..
Asus Zenbook 14 U425
VMix Version 24.0.0.63
Slaver
#2 Posted : Thursday, July 8, 2021 5:42:50 PM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
What resolutions did you try in vMix?
Slaver
#3 Posted : Thursday, July 8, 2021 9:29:27 PM(UTC)
Slaver
Maybe you have to use one of the legacy drivers.
Invexabi
#4 Posted : Thursday, July 8, 2021 9:36:40 PM(UTC)
Invexabi
do i have to download a new driver?, which one do you mean?...
i've tried to added input from external Camera even iVCam, but doesnt work....always Pop Up on VMix Screen Capture Resolution is not support by this Device
xaver
#5 Posted : Friday, July 9, 2021 3:56:47 AM(UTC)
xaver
Originally Posted by: Invexabi Go to Quoted Post
hi there.....
My laptop..
what's the max resolution of your camera and did you open that resolution in vMix?
Invexabi
#6 Posted : Saturday, July 10, 2021 2:06:19 AM(UTC)
Invexabi
resolution 1920 x 1080
mavik
#7 Posted : Saturday, July 10, 2021 2:36:14 AM(UTC)
mavik
Was thanked: 196 time(s) in 176 post(s)
Some integrated cams pretend (or simulate) a higher resolutions as they really have. Go try 720p. It's very rare to have build in webcams to have a FHD resolution.
AlanZ
#8 Posted : Saturday, July 10, 2021 4:31:11 AM(UTC)
AlanZ
This might help
When creating the camera input, try setting the video format to something that won't be compatible (for example ARGB32), then try to save the input.
You'll get an error dialog box that lists all of the available formats for that camera.
Invexabi
#9 Posted : Saturday, July 10, 2021 1:04:35 PM(UTC)
Invexabi
i've tried, but the result is same......
xaver
#10 Posted : Saturday, July 10, 2021 3:35:51 PM(UTC)
xaver
try
https://webrtchacks.gith...ebRTC-Camera-Resolution/
and you will see the resolution of you camera
then try that resolution in vMix
