hi there.....
I'm having trouble using the internal camera, all camera sources will get a notice Capture Resolution is not support by this Device...can anyone help me?... The camera works normally when I use it on OBS or Zoom
My laptop.. Asus Zenbook 14 U425
VMix Version 24.0.0.63
Thanks: 27 times Was thanked: 8 time(s) in 8 post(s)
What resolutions did you try in vMix?
Maybe you have to use one of the legacy drivers.
do i have to download a new driver?, which one do you mean?... i've tried to added input from external Camera even iVCam, but doesnt work....always Pop Up on VMix Screen Capture Resolution is not support by this Device
what's the max resolution of your camera and did you open that resolution in vMix?
Originally Posted by: Slaver  What resolutions did you try in vMix? resolution 1920 x 1080
Joined: 4/23/2017(UTC) Posts: 1,481  Location: Germany Thanks: 3 times Was thanked: 196 time(s) in 176 post(s)
Some integrated cams pretend (or simulate) a higher resolutions as they really have. Go try 720p. It's very rare to have build in webcams to have a FHD resolution.
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
This might help
When creating the camera input, try setting the video format to something that won't be compatible (for example ARGB32), then try to save the input. You'll get an error dialog box that lists all of the available formats for that camera.
Originally Posted by: mavik  Some integrated cams pretend (or simulate) a higher resolutions as they really have. Go try 720p. It's very rare to have build in webcams to have a FHD resolution. i've tried, but the result is same......
