Joined: 11/6/2020(UTC) Posts: 21  Location: Saint-Petersburg Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Hello!
On vMix 24 got capture problem. If I adding more then 2 inputs via Decklink Duo 2 framerate is falling form 50 to smthing like 15-25
Render time is about 6 ms, GPU Mem: 21%, CPU vMix 7%, Total 12%, so system load is not too high
input 1 - Notebook 1920x1080@50p input 3 - Notebook 1920x1080@50p input 2 - Camera - Sony PXW-Z150 1920x1080@50p or 1920x1080@50i input 4 - Camera - Sony PXW-Z150 1920x1080@50p or 1920x1080@50i
operating system - Windows 10 motherboard - B460 AORUS PRO AC processor - Intel(R) Core(TM) i7-10700 CPU graphic card - NVIDIA GeForce RTX 2070 SUPER RAM - 32 Gb
attempts to solve the problem:
in BIOS Above 4G Decoding is enabled changed Desktop Video from 12 to 11.7 reinstall and update vMix changed camera output from 1920x1080@50p to 1920x1080@50i
In the manual of your board you can find this:
1 x PCI Express x16 slot, running at x4 (PCIEX4) * The PCIEX4 slot shares bandwidth with the M2P_SB connector. The PCIEX4 slot operates at up to x2 mode when a PCIe SSD is installed in the M2P_SB connector.
And your problem looks like the card has only enough bandwidth for 2 camera's. So I would investigate this, is there a SSD installed in M2P_SB?
 1 user thanked Mathijs for this useful post.
solution was to change Window Capture Method to GDI. With this setting Fullscreens works fine
And your problem looks like the card has only enough bandwidth for 2 camera's. So I would investigate this, is there a SSD installed in M2P_SB? no SSD installed, 4 lines is enough for 4 inputs. Problem was in Window Capture Method
Joined: 7/25/2013(UTC) Posts: 5 Location: Czech republic
Originally Posted by: svetotehnik  solution was to change Window Capture Method to GDI. With this setting Fullscreens works fine Can you help me please where to change it? Thanks
Originally Posted by: porez  Originally Posted by: svetotehnik  solution was to change Window Capture Method to GDI. With this setting Fullscreens works fine Can you help me please where to change it? Thanks
