svetotehnik
#1 Posted : Thursday, May 13, 2021 5:04:02 PM(UTC)
svetotehnik
Russian Federation
Hello!
On vMix 24 got capture problem. If I adding more then 2 inputs via Decklink Duo 2 framerate is falling form 50 to smthing like 15-25
Render time is about 6 ms, GPU Mem: 21%, CPU vMix 7%, Total 12%, so system load is not too high
input 1 - Notebook 1920x1080@50p
input 3 - Notebook 1920x1080@50p
input 2 - Camera - Sony PXW-Z150 1920x1080@50p or 1920x1080@50i
input 4 - Camera - Sony PXW-Z150 1920x1080@50p or 1920x1080@50i
operating system - Windows 10
motherboard - B460 AORUS PRO AC
processor - Intel(R) Core(TM) i7-10700 CPU
graphic card - NVIDIA GeForce RTX 2070 SUPER
RAM - 32 Gb
attempts to solve the problem:
in BIOS Above 4G Decoding is enabled
changed Desktop Video from 12 to 11.7
reinstall and update vMix
changed camera output from 1920x1080@50p to 1920x1080@50i
Mathijs
#2 Posted : Sunday, May 23, 2021 6:01:31 AM(UTC)
Mathijs
In the manual of your board you can find this:
1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the M2P_SB connector. The PCIEX4 slot operates at up to x2 mode when a PCIe SSD is installed in the M2P_SB connector.
And your problem looks like the card has only enough bandwidth for 2 camera's.
So I would investigate this, is there a SSD installed in M2P_SB?
thanks 1 user thanked Mathijs for this useful post.
svetotehnik on 5/28/2021(UTC)
svetotehnik
#3 Posted : Friday, May 28, 2021 11:41:02 PM(UTC)
svetotehnik
Russian Federation
solution was to change Window Capture Method to GDI. With this setting Fullscreens works fine
svetotehnik
#4 Posted : Friday, May 28, 2021 11:42:30 PM(UTC)
svetotehnik
Russian Federation
no SSD installed, 4 lines is enough for 4 inputs. Problem was in Window Capture Method
porez
#5 Posted : Monday, June 7, 2021 4:45:57 AM(UTC)
porez
Can you help me please where to change it?
svetotehnik
#6 Posted : Friday, June 11, 2021 5:59:36 PM(UTC)
svetotehnik
Russian Federation
Similar Topics
Decklink Duo 2 dropping frames?? (Hardware Compatibility)
by KirenPollard 10/8/2021 6:28:58 PM(UTC)
