clibil
#1 Posted : Thursday, April 29, 2021 5:34:18 AM(UTC)
clibil
Hi there !
We often use Powerpoint files in our VMix recordings but inevitably we spot typos in the slides while we are working on the recording.
Would it be possible to allow a quick reload of the Powerpoint file back into VMix after editing the source ?
Thanks from a very satisfied user
mavik
#2 Posted : Thursday, April 29, 2021 7:23:37 AM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
Just make the edits and import again as a new input.
If you need a fix input for some reason you use a mini mixer output as an input for that.
kroskopf
#3 Posted : Thursday, June 10, 2021 1:03:38 AM(UTC)
kroskopf
Specifically, this would be available with a right-click on the PowerPoint input. When you right-click you'd see...
  • SlideShow Settings
  • Re-import PowerPoint
This is a nice-to-have feature request, but the sequence to reload a PowerPoint is very fast.
  • Click the settings cog on the input
  • Click "General" on the input settings if you're not already there
  • Click Change (No need to browse or anything... the PowerPoint file is already selected)
  • Click OK
OldDesertLizard
#4 Posted : Saturday, September 18, 2021 10:38:48 PM(UTC)
OldDesertLizard
Well, thanks for the info on how to do this quickly... I was almost to the point of wondering if I'd just have to shut down vMix and restart.
I'm wondering if a script can be created that will do this, and then set a (local) shortcut to reload by running the script.
But yes... adding "Refresh PowerPoint Slides" to the context menu when clicking a PowerPoint screen would be a really great idea.
