Feature Requests
Quick reload of Powerpoint
Joined: 3/30/2020(UTC) Posts: 17   Location: Leran Thanks: 14 times
Hi there ! We often use Powerpoint files in our VMix recordings but inevitably we spot typos in the slides while we are working on the recording. Would it be possible to allow a quick reload of the Powerpoint file back into VMix after editing the source ? Thanks from a very satisfied user
Just make the edits and import again as a new input. If you need a fix input for some reason you use a mini mixer output as an input for that.
Joined: 7/15/2020(UTC) Posts: 6  Location: Bensenville Thanks: 1 times
Specifically, this would be available with a right-click on the PowerPoint input. When you right-click you'd see... - SlideShow Settings
- Re-import PowerPoint
This is a nice-to-have feature request, but the sequence to reload a PowerPoint is very fast. - Click the settings cog on the input
- Click "General" on the input settings if you're not already there
- Click Change (No need to browse or anything... the PowerPoint file is already selected)
- Click OK
Joined: 9/5/2021(UTC) Posts: 7   Was thanked: 1 time(s) in 1 post(s)
Well, thanks for the info on how to do this quickly... I was almost to the point of wondering if I'd just have to shut down vMix and restart.
I'm wondering if a script can be created that will do this, and then set a (local) shortcut to reload by running the script.
But yes... adding "Refresh PowerPoint Slides" to the context menu when clicking a PowerPoint screen would be a really great idea.
Feature Requests
