running 24.0.0.51 - cant get any to load in the plugin...installed path seems correct...help?
Have you made sure you are Running vMix in 64 bit ?
Hi, yes x64....not seeing why nothing is loading path is: c:\program files\common\VST3....? ahhhh puzzling ?
