Joined: 7/9/2019(UTC) Posts: 10  Location: Iowa Thanks: 1 times
I have some audio plugins I would love to use with vmix. All I can find is that once they are installed, vMix will see them. Well, it does not.
I would love to use some of my Reaper vst3 plugins, and I have a couple of others from 3rd party suppliers. I can use them in other software, notably Reaper, but not in vMix.
How do I make them visible?
The problem is vMix only looks at: C:\Program Files\Common Files\VST3 to locate the plugins unlike Reaper which searches in other locations. In order to solve this problem I went through a headache to get vMix to see VST3 that were not showing up. PM me. Maybe I can help.
