Akai midimix activators question
Joined: 1/29/2021(UTC) Posts: 16  Location: valencia Thanks: 2 times
Hello, I search info but not find the solution. https://forums.vmix.com/posts/t17517-MidimixI create Activator to AKAI midimix , the device it is Enable Event: InputAudio Input : Video Type Button LED Always it is lighther ####################################### I create also another activator Event: Default Type : Off But the button always have light, the audio turn on and off but the light persist. reggards
OK I solved finally.
I create activator that disable the lights
Event: Default Type : Off Note : 1-27
And Anoher:
Event: InputAudio Type : AKAI APCMINI Square LED Note : 1-1 (Only the button) THIS IS THE TRICK REVISE BECAUSE THE PROGRAM PUT MORE RANGE
1-1 4-4 7-7
reggards
