isidto
#1 Posted : Thursday, March 4, 2021 6:03:16 AM(UTC)
isidto
Spain
I search info but not find the solution.
https://forums.vmix.com/posts/t17517-Midimix
I create Activator to AKAI midimix , the device it is Enable
Event: InputAudio
Input : Video
Type Button LED
Always it is lighther
I create also another activator
Event: Default
Type : Off
But the button always have light, the audio turn on and off but the light persist.
reggards
isidto
#2 Posted : Thursday, March 4, 2021 7:12:45 AM(UTC)
isidto
Spain
OK I solved finally.
I create activator that disable the lights
Event: Default
Type : Off
Note : 1-27
And Anoher:
Event: InputAudio
Type : AKAI APCMINI Square LED
Note : 1-1 (Only the button) THIS IS THE TRICK REVISE BECAUSE THE PROGRAM PUT MORE RANGE
1-1
4-4
7-7
reggards
