Last night I was trying to record, using Vmix, my pastor's sermon. I encountered a problem I was not able to resolve and it is my hope that those more experienced with Vmix in this forum may shed some light on a solution.
Despite Render Time, GPU. CPU numbers all being in the low single digits, the video in the live view window was lagging significantly. Here is a link to a short 17 sec. test clip to show what it looked like:
https://youtu.be/o2_uZ_F1pfQI have uploaded some screenshots of the configurations in use, as well as the configuration of the equipment I am using.
The strangest thing is, when I test this at home, there was zero lag; so I am completely perplexed. I am scheduled to retry another recording this evening, assuming I am able to find and correct the problem; to that end, I really could use some assistance.
Computer: MSI Laptop GT80 2QE
CPU: i7-5950HQ @2.90GHz
RAM: 32 GB
HD: Samsung SSD 860 EVO M.2 2TB
Camera: SONY FDR AX100
Vmix 4K: 23.0.0.65 x64
Capture Card External: AVIO 4K (HDMI from Camera to USB)
Sound Input: Rode Wireless Go into Camera
Log file to the 17sec clip linked above:
10/22/2020 7:53:29 PM, Version: 23.0.0.65 x64
10/22/2020 7:53:29 PM, Size: 1920x1080
10/22/2020 7:53:29 PM, System: NTSC 29.97p
10/22/2020 7:53:29 PM, Codec: H264
10/22/2020 7:53:29 PM, Format: UYVY 16 1498831189
10/22/2020 7:53:29 PM, AudioDevice: vMix Audio
10/22/2020 7:53:29 PM, AudioFormat: 48000 Hz 16 Bit 2 Channels
10/22/2020 7:53:29 PM, AudioDelay: 0
10/22/2020 7:53:29 PM, RestartInterval: 0
10/22/2020 7:53:29 PM, Buffers: 10
10/22/2020 7:53:29 PM, BitRate: 8 Mbps
10/22/2020 7:53:29 PM, AudioBitRate: 128 Kbps
10/22/2020 7:53:29 PM, StartRecording
10/22/2020 7:53:46 PM, StopRecording
10/22/2020 7:53:46 PM, Duration: 00:00:17
10/22/2020 7:53:46 PM, Frames: 515
10/22/2020 7:53:46 PM, DroppedFrames: 0
10/22/2020 7:53:46 PM, DueToSourceFrameRate: 0
10/22/2020 7:53:46 PM, DueToHardDiskOrCPU: 0
10/22/2020 7:53:46 PM, DroppedSamples: 0
10/22/2020 7:53:46 PM, MissedSamples: 0
10/22/2020 7:53:46 PM, SyncedSamples: 0
10/22/2020 7:53:46 PM, AudioOffset: 0
10/22/2020 7:53:46 PM, AudioDelay: 0
10/22/2020 7:53:46 PM, AudioEngine
10/22/2020 7:53:46 PM, Running: True
10/22/2020 7:53:46 PM, SampleRate: 48000hz 16 Bit
10/22/2020 7:53:46 PM, MixingErrors: 0
10/22/2020 7:53:46 PM, Streams
10/22/2020 7:53:46 PM, Mixer
10/22/2020 7:53:46 PM, Samples: 10246
10/22/2020 7:53:46 PM, Dropped: Read 0 Write 0
10/22/2020 7:53:46 PM, Latency: 0 ms
10/22/2020 7:53:46 PM, Errors: 0
10/22/2020 7:53:46 PM, Headphones
10/22/2020 7:53:46 PM, Latency: 10 ms
10/22/2020 7:53:46 PM, DirectShow
10/22/2020 7:53:46 PM, Samples: 9225
10/22/2020 7:53:46 PM, Dropped: Read 2 Write 0
10/22/2020 7:53:46 PM, Latency: 40 ms
10/22/2020 7:53:46 PM, TargetLatency: 67 ms
10/22/2020 7:53:46 PM, Resampled: 0/40
(73kb) downloaded 0 time(s).
(59kb) downloaded 0 time(s).Thank you.
