AlanC
#1 Posted : Saturday, October 24, 2020 1:47:35 AM(UTC)
AlanC
Last night I was trying to record, using Vmix, my pastor's sermon. I encountered a problem I was not able to resolve and it is my hope that those more experienced with Vmix in this forum may shed some light on a solution.
Despite Render Time, GPU. CPU numbers all being in the low single digits, the video in the live view window was lagging significantly. Here is a link to a short 17 sec. test clip to show what it looked like: https://youtu.be/o2_uZ_F1pfQ
I have uploaded some screenshots of the configurations in use, as well as the configuration of the equipment I am using.
The strangest thing is, when I test this at home, there was zero lag; so I am completely perplexed. I am scheduled to retry another recording this evening, assuming I am able to find and correct the problem; to that end, I really could use some assistance.
Computer: MSI Laptop GT80 2QE
CPU: i7-5950HQ @2.90GHz
RAM: 32 GB
HD: Samsung SSD 860 EVO M.2 2TB
Camera: SONY FDR AX100
Vmix 4K: 23.0.0.65 x64
Capture Card External: AVIO 4K (HDMI from Camera to USB)
Sound Input: Rode Wireless Go into Camera
Log file to the 17sec clip linked above:
10/22/2020 7:53:29 PM, Version: 23.0.0.65 x64
10/22/2020 7:53:29 PM, Size: 1920x1080
10/22/2020 7:53:29 PM, System: NTSC 29.97p
10/22/2020 7:53:29 PM, Codec: H264
10/22/2020 7:53:29 PM, Format: UYVY 16 1498831189
10/22/2020 7:53:29 PM, AudioDevice: vMix Audio
10/22/2020 7:53:29 PM, AudioFormat: 48000 Hz 16 Bit 2 Channels
10/22/2020 7:53:29 PM, AudioDelay: 0
10/22/2020 7:53:29 PM, RestartInterval: 0
10/22/2020 7:53:29 PM, Buffers: 10
10/22/2020 7:53:29 PM, BitRate: 8 Mbps
10/22/2020 7:53:29 PM, AudioBitRate: 128 Kbps
10/22/2020 7:53:29 PM, StartRecording
10/22/2020 7:53:46 PM, StopRecording
10/22/2020 7:53:46 PM, Duration: 00:00:17
10/22/2020 7:53:46 PM, Frames: 515
10/22/2020 7:53:46 PM, DroppedFrames: 0
10/22/2020 7:53:46 PM, DueToSourceFrameRate: 0
10/22/2020 7:53:46 PM, DueToHardDiskOrCPU: 0
10/22/2020 7:53:46 PM, DroppedSamples: 0
10/22/2020 7:53:46 PM, MissedSamples: 0
10/22/2020 7:53:46 PM, SyncedSamples: 0
10/22/2020 7:53:46 PM, AudioOffset: 0
10/22/2020 7:53:46 PM, AudioDelay: 0
10/22/2020 7:53:46 PM, AudioEngine
10/22/2020 7:53:46 PM, Running: True
10/22/2020 7:53:46 PM, SampleRate: 48000hz 16 Bit
10/22/2020 7:53:46 PM, MixingErrors: 0
10/22/2020 7:53:46 PM, Streams
10/22/2020 7:53:46 PM, Mixer
10/22/2020 7:53:46 PM, Samples: 10246
10/22/2020 7:53:46 PM, Dropped: Read 0 Write 0
10/22/2020 7:53:46 PM, Latency: 0 ms
10/22/2020 7:53:46 PM, Errors: 0
10/22/2020 7:53:46 PM, Headphones
10/22/2020 7:53:46 PM, Latency: 10 ms
10/22/2020 7:53:46 PM, DirectShow
10/22/2020 7:53:46 PM, Samples: 9225
10/22/2020 7:53:46 PM, Dropped: Read 2 Write 0
10/22/2020 7:53:46 PM, Latency: 40 ms
10/22/2020 7:53:46 PM, TargetLatency: 67 ms
10/22/2020 7:53:46 PM, Resampled: 0/40
Camera Config.JPG (73kb) downloaded 0 time(s). Recording Config.JPG (59kb) downloaded 0 time(s).
Thank you.
Vince Beck
#2 Posted : Saturday, October 24, 2020 3:07:37 AM(UTC)
Vince Beck
Rank:: Advanced Member
It's likely an issue with the USB capture device or the port and not VMix.
Is there anything else plugged on the same side on the laptop? Usually, the same side ports share the same bus.
Also make sure you have the device driver installed.
