Scionn
#1 Posted : Saturday, October 10, 2020 4:04:22 AM(UTC)
Scionn
Italy
Playng slides on VMIX make possible to not degrade it in case of network problems... but there will be a way to give the control to the remote side to move to the next or the previous slide.... controlling a powerpoint input or simply showing something like a traffic light for the operator....
Aecast
#2 Posted: : Sunday, October 11, 2020 11:26:14 AM(UTC)
Aecast
Was thanked: 10 time(s) in 7 post(s)
+1
be a good feature to have this built in for each caller.
You can also achieve this with some VB scripting and fetching say a click status from a webapp
Chris Daum
#3 Posted : Tuesday, December 1, 2020 8:10:57 PM(UTC)
Chris Daum
Germany
You might also use internetclicker.com
works fine!
