Feature Requests
Vmix CALL buttons to move next and previous slide on VMIX
Playng slides on VMIX make possible to not degrade it in case of network problems... but there will be a way to give the control to the remote side to move to the next or the previous slide.... controlling a powerpoint input or simply showing something like a traffic light for the operator....
Joined: 3/25/2020(UTC) Posts: 48  Location: Chichester Was thanked: 10 time(s) in 7 post(s)
+1
be a good feature to have this built in for each caller. You can also achieve this with some VB scripting and fetching say a click status from a webapp
Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
You might also use internetclicker.com works fine!
Feature Requests
