Feature Requests
Vmix CALL buttons to move next and previous slide on VMIX
Joined: 10/10/2020(UTC) Posts: 2 ![Italy Italy](/Content/images/flags/IT.png) Location: Osimo
Playng slides on VMIX make possible to not degrade it in case of network problems... but there will be a way to give the control to the remote side to move to the next or the previous slide.... controlling a powerpoint input or simply showing something like a traffic light for the operator....
Joined: 3/25/2020(UTC) Posts: 48 ![United Kingdom United Kingdom](/Content/images/flags/GB.png) Location: Chichester Was thanked: 10 time(s) in 7 post(s)
+1
be a good feature to have this built in for each caller. You can also achieve this with some VB scripting and fetching say a click status from a webapp
Joined: 11/20/2020(UTC) Posts: 74 ![Man Man](/Themes/yafpro/male.gif) ![Germany Germany](/Content/images/flags/DE.png) Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
You might also use internetclicker.com works fine!
Feature Requests
