NDI
Random Audio Loss on vMix Desktop Capture
Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Currently I have issue with vMix Desktop Capture, so I'm using a Computer as a Video Feed to vMix in another Computer. At first the Video Feed works well with Good Video and Audio signals, but as I use it more sometimes the Audio was lost randomly (the Video Signal still OK) until I restarted vMix Desktop Capture. Every time I restarted vMix Desktop Capture, the audio will be restored. Is this a known issue?
Thanks in advance.
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
A bad experience over time points to a leakage somewhere. Please check the task monitor if you see an increase in memory usage or the like. Another issue could be the antivirus. Desktop capture sends a stream, the AV buffers and waits for the end of the file (that never comes) and overruns a buffer. Restarting the app clears the situation and the game can start again. Try with AV off and see if there is a difference.
NDI
