gpdipalmerahtimur
#1 Posted : Tuesday, September 22, 2020 11:46:19 AM(UTC)
gpdipalmerahtimur
Indonesia
Currently I have issue with vMix Desktop Capture, so I'm using a Computer as a Video Feed to vMix in another Computer. At first the Video Feed works well with Good Video and Audio signals, but as I use it more sometimes the Audio was lost randomly (the Video Signal still OK) until I restarted vMix Desktop Capture. Every time I restarted vMix Desktop Capture, the audio will be restored. Is this a known issue?
Thanks in advance.
mavik
#2 Posted : Tuesday, September 22, 2020 4:17:05 PM(UTC)
mavik
A bad experience over time points to a leakage somewhere. Please check the task monitor if you see an increase in memory usage or the like. Another issue could be the antivirus. Desktop capture sends a stream, the AV buffers and waits for the end of the file (that never comes) and overruns a buffer. Restarting the app clears the situation and the game can start again. Try with AV off and see if there is a difference.
