ChuckRogers
#1 Posted : Wednesday, September 9, 2020 9:01:34 AM(UTC)
ChuckRogers
I have had this working.. for one day.. How do I reset for day 2? I right-click on the timer and hit "reload" and nothing.. timer still at zero.. I check the title editor and everything looks good.. same code that worked for yesterday. I delete and re-enter the faactory version of the "countdown to time" function and simply change the 3 (3 pm) to a 1 (1 pm).... nothing.. Do I have to re-build the clock from scratch each time (delete the input and create a new one)??
#2 Posted : Wednesday, September 9, 2020 9:19:16 AM(UTC)
Doesn't make sense, something is off
at what time are you changing it
Maybe show your code (screenshot)
Similar Topics
Does HD license support Countdown to Time (General Discussion)
by neuegs 9/3/2026 10:04:02 AM(UTC)
Make OnCountdownRemaining and OnCountdownComplete triggers work with the countdown to time function (Feature Requests)
by guidogast 11/3/2025 6:29:58 PM(UTC)
Specific field (available for data source connection) for countdown to time (Feature Requests)
by TL68 1/18/2024 6:34:52 PM(UTC)
Triggers not working with "Countdown to Time" (General Discussion)
by everything 9/20/2021 8:48:02 AM(UTC)
OnCountdownComplete + Countdown To Time (General Discussion)
by omfgblondie 5/11/2021 8:46:54 PM(UTC)
Countdown To Time Trigger does not work (General Discussion)
by Vadim 11/1/2020 1:45:03 PM(UTC)
Trigger for countdown to time? (General Discussion)
by BasilChessman 9/4/2020 6:19:49 AM(UTC)
Countdown to Time Trigger (Feature Requests)
by john30120 1/19/2020 10:54:33 AM(UTC)
Countdown to time with stop time (General Discussion)
by john30120 1/2/2020 9:02:06 AM(UTC)
