Joined: 9/7/2020(UTC) Posts: 13  Location: Louisville Thanks: 5 times
I have had this working.. for one day.. How do I reset for day 2? I right-click on the timer and hit "reload" and nothing.. timer still at zero.. I check the title editor and everything looks good.. same code that worked for yesterday. I delete and re-enter the faactory version of the "countdown to time" function and simply change the 3 (3 pm) to a 1 (1 pm).... nothing.. Do I have to re-build the clock from scratch each time (delete the input and create a new one)??
Doesn't make sense, something is off at what time are you changing it Maybe show your code (screenshot)
