ifeinberg
#1 Posted : Tuesday, July 21, 2020 12:13:43 PM(UTC)
ifeinberg
Can you monitor master audio and a bus (say A bus) in headsets during production? Would like to hear a remote producer through vmixcall but don't want them on the program recording. Is this possible?
Thank you!
dmwkr
#2 Posted : Tuesday, July 21, 2020 3:52:36 PM(UTC)
dmwkr
One way could be: Set up another Bus (B), send your M and A inputs also to Bus B, solo Bus B with the S button.
WaltG
#3 Posted : Saturday, August 29, 2020 8:19:00 AM(UTC)
WaltG
Why not just remove the headphones from "headphones", assign them as the audio device for bus B instead, then add anything you want to monitor to bus B?
Personally, I found the fader easier to adjust than the headphone knob, so I did that anyway a while back--not sure why it wouldn't work here.
