Monitor master and bus audio in headsets
Joined: 6/13/2020(UTC) Posts: 14  Location: Atlanta, GA
Can you monitor master audio and a bus (say A bus) in headsets during production? Would like to hear a remote producer through vmixcall but don't want them on the program recording. Is this possible?
Thank you!
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
One way could be: Set up another Bus (B), send your M and A inputs also to Bus B, solo Bus B with the S button.
Joined: 8/29/2020(UTC) Posts: 6  Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: dmwkr  One way could be: Set up another Bus (B), send your M and A inputs also to Bus B, solo Bus B with the S button. Why not just remove the headphones from "headphones", assign them as the audio device for bus B instead, then add anything you want to monitor to bus B? Personally, I found the fader easier to adjust than the headphone knob, so I did that anyway a while back--not sure why it wouldn't work here.
