	Audio Input from Behringer X32
                Forum, My church just obtained a Behringer X32 soundboard.  Can anyone tell me what I need to get a feed of the output from the X32 into VMix on my Windows 10 PC?  Please let me know what settings, drivers etc I would need to see the output from the X32 as an Audio input in VMix.
  Thanks, Rob.
                There are multiple options available: 1. Using native usb directly from your X32 to your PC - download drivers from Behringer support site 2. Using Live interface on X32 linked to your PC - download X-Live software/drivers from Behringer support site 3. Using networked mac priority network with X32 Dante interface - Virtual Dante sound card from Audinate (not free)
  In all cases there will be a leaning curve with regards to X32 setup, signal routing, scenes, presets, recording, etc.
  In short - your setup will differ based on the approach and connectivity you choose. As an example - I am relying entirely on Dante networking (not endorsing, nor affiliated with) with 2x X32 Rack, 1x X32 Console, 3x SD16, 1x S32; all feeding to AKD160D drivers with Apart COLW101 and IQ 100 Ultranet for special gigs; where audio from all X32's is mixed in Vmix with Dante virtual interface (ASIO format).
  Andy
              1 user thanked andser for this useful post.
                Hello Andy, thanks for your quick reply, this is helpful and confirms what I suspected.  Configuring the X32 is outside my scope - I leave that to the sound guy. I've read a bit about the Dante networking option but that requires a new card in the X32 so I can't pursue that one.  But I will definitely try the native USB from the X32 - I have already downloaded both the X-LIVE and X-USB drivers from Behringer.  Hope this works. Thanks again, Rob.
                Hey Rob,
  Best of luck in your setup. Worth to mention - if you are planning on "stitching" audio and video in Vmix, expect a "lipsync" challenge. Since I'm using mixture of the rtp, rtmp and NDI based on the various sources capabilities I had to build a GPS disciplined stratum clock (NTP) to keep all cats in the basket. In short - a good time source for system and devices clock sync will be your friend.
  Andy
