	Adobe only recognises the first 2 frames of Vmix ProRes Recoding
  we recorded an event yesterday of about 3 hours. It was 1920x1080i50 and was recoded in ProRes LT in a mov container with Vmix 23.
  Today I imported the recoding into Premiere CC and Premiere only sees the first two frames. So all the clips are only 2 frames long. The filesize indicates that the recording is OK and in the right lenght. But Premiere sees all the clips only as 2frame long.
  I can play the clips back in VMIX without any problems.
  What is going on here?
  Thanks and cheers
  pro
                Ok - figured it out:
  If you record FFMPG with ProRes LT in a Quicktime file (non indexed), the files shows only the first 2 frames in Premiere CC2019. If you select "Quicktime indexed" in Vmix, it shows the correct lenght. So make sure to always select Quicktime (indexed).
  Is there a simple way to convert a Quicktime recording to an indexed Quicktime file?
  Thanks and cheers
  pro
 Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
                Quote:Is there a simple way to convert a Quicktime recording to an indexed Quicktime file?  vMix Video Tool
