streaming---pro
#1 Posted : Friday, July 10, 2020 11:10:19 PM(UTC)
streaming---pro
Germany
we recorded an event yesterday of about 3 hours. It was 1920x1080i50 and was recoded in ProRes LT in a mov container with Vmix 23.
Today I imported the recoding into Premiere CC and Premiere only sees the first two frames. So all the clips are only 2 frames long. The filesize indicates that the recording is OK and in the right lenght. But Premiere sees all the clips only as 2frame long.
I can play the clips back in VMIX without any problems.
What is going on here?
Thanks and cheers
pro
streaming---pro
#2 Posted : Saturday, July 11, 2020 9:12:33 PM(UTC)
streaming---pro
Germany
Ok - figured it out:
If you record FFMPG with ProRes LT in a Quicktime file (non indexed), the files shows only the first 2 frames in Premiere CC2019. If you select "Quicktime indexed" in Vmix, it shows the correct lenght. So make sure to always select Quicktime (indexed).
Is there a simple way to convert a Quicktime recording to an indexed Quicktime file?
Thanks and cheers
pro
#3 Posted : Saturday, July 11, 2020 11:43:12 PM(UTC)
Views messages in topic : 2,721
vMix Video Tool
