tvoy_sokolov
#1 Posted : Wednesday, May 6, 2020 8:42:35 PM(UTC)
tvoy_sokolov
Russian Federation
Hey Ya. I found a problem. It is associated with the item "Strict CBR" in the stream settings.
When a static picture is broadcast, the bitrate drops.
When there is a dynamic frame on the air, the bitrate tends to a predetermined value.
In the stream settings, the "Strict CBR" checkbox is selected. How can I make a real constant bitrate?
DELL G5 15, Windows 10 Pro (1909), vMix 23.0.0.51, HD License
xaver
#2 Posted : Thursday, May 7, 2020 4:19:27 AM(UTC)
xaver
why do ypu need a constant bitrate?
why are you screaming so loud?
mavik
#3 Posted : Thursday, May 7, 2020 5:34:21 AM(UTC)
mavik
Was thanked: 196 time(s) in 176 post(s)
Constant bitrate is an illusion. I know not one product that is capable of a 100% locked bitrate, no matter what you throw at it. Constant bitrate is more a flattened ABR. And why waste data. It really doesn't makes sense. Yes, if you stream a static content and you have a monitoring on bandwidth it will throw an alarm. No question.
