Hey Ya. I found a problem. It is associated with the item "Strict CBR" in the stream settings. 1.jpg (86kb) downloaded 13 time(s).When a static picture is broadcast, the bitrate drops.  2.jpg (78kb) downloaded 8 time(s).When there is a dynamic frame on the air, the bitrate tends to a predetermined value.  3.jpg (91kb) downloaded 8 time(s).In the stream settings, the "Strict CBR" checkbox is selected. How can I make a real constant bitrate?DELL G5 15, Windows 10 Pro (1909), vMix 23.0.0.51, HD License
why do ypu need a constant bitrate? why are you screaming so loud?
Constant bitrate is an illusion. I know not one product that is capable of a 100% locked bitrate, no matter what you throw at it. Constant bitrate is more a flattened ABR. And why waste data. It really doesn't makes sense. Yes, if you stream a static content and you have a monitoring on bandwidth it will throw an alarm. No question.
