Joined: 2/28/2019(UTC) Posts: 1  Location: mONTEVIDEO
Uso easy on air y me gustaría mandar órdenes a través de esta aplicación a través de TCP Command a vmix. Que comandos debería colocar para poner un input en programa?
Originally Posted by: titomarenales  I use easy on air and I would like to send orders through this application through TCP Command to vmix. What commands should I put to put an input in the program? I guess Cut, CutDirect or Fade will be the appropriate function. You can take a look at https://www.vmix.com/hel...utFunctionReference.html under the Transition section. Note that the Cut and Fade function is actually not in the list somehow...
