titomarenales
#1 Posted : Thursday, April 16, 2020 2:48:11 PM(UTC)
titomarenales
Uruguay
Uso easy on air y me gustaría mandar órdenes a través de esta aplicación a través de TCP Command a vmix. Que comandos debería colocar para poner un input en programa?
stigaard
#2 Posted : Thursday, April 16, 2020 3:15:08 PM(UTC)
stigaard
Denmark
Originally Posted by: titomarenales Go to Quoted Post
I use easy on air and I would like to send orders through this application through TCP Command to vmix. What commands should I put to put an input in the program?
I guess Cut, CutDirect or Fade will be the appropriate function.
You can take a look at https://www.vmix.com/hel...utFunctionReference.html under the Transition section. Note that the Cut and Fade function is actually not in the list somehow...
