 Joined: 2/28/2019(UTC) Posts: 1  Location: mONTEVIDEO |
                Uso easy on air y me gustaría mandar órdenes a través de esta aplicación a través de TCP Command a vmix. Que comandos debería colocar para poner un input en programa?  |
 Joined: 5/20/2015(UTC) Posts: 492   Location: Copenhagen, DenmarkThanks: 411 timesWas thanked: 102 time(s) in 79 post(s)
                Originally Posted by: titomarenales  I use easy on air and I would like to send orders through this application through TCP Command to vmix. What commands should I put to put an input in the program?  I guess Cut, CutDirect or Fade will be the appropriate function.  You can take a look at https://www.vmix.com/hel...utFunctionReference.html  under the Transition section. Note that the Cut and Fade function is actually not in the list somehow...  |
