cmpenney
#1 Posted : Saturday, February 22, 2020 4:40:01 AM(UTC)
cmpenney
You have been a member since:: 2/20/2020(UTC)
I'm trying to use the NDI-HX iPhone with vMix. When I go into the Add Input option and select NDI. I see the device listed although the box is black and I can add the input and hear sound (although with a very noticable delay) However I can't get an video. Every couple minutes it will update with a still image but I'm not getting anything remotely resembling video.
Any thoughts on what I might be doing wrong?
#2 Posted : Saturday, February 22, 2020 8:28:32 PM(UTC)
Was thanked: 4726 time(s) in 1618 post(s)
Does it work in the Studio Monitor app on the same computer?
mavik
#3 Posted : Saturday, February 22, 2020 10:20:11 PM(UTC)
mavik
Was thanked: 196 time(s) in 176 post(s)
Why don't you use the Larix Broadcaster App and go via SRT. You may even bridge WAN -> LAN which is not possible with NDI natively. In essence as long as you have reception on your iphone you can submit into vmix that can be local/remote or even a complete other country.
cmpenney
#4 Posted : Thursday, February 27, 2020 8:49:28 AM(UTC)
cmpenney
Mavik, I'll give that a try.
FWIW, It appears to have been a network issue. Same setup on a different WiFi network and everything worked.
mavik
#5 Posted : Thursday, February 27, 2020 4:13:04 PM(UTC)
mavik
Glad you figured it out.
Feel free to test larix broadcaster it might give you a more secure link. You can use SRT LAN -> LAN or WAN -> LAN
