NDI
NDI HX iPhone App Issue
I'm trying to use the NDI-HX iPhone with vMix. When I go into the Add Input option and select NDI. I see the device listed although the box is black and I can add the input and hear sound (although with a very noticable delay) However I can't get an video. Every couple minutes it will update with a still image but I'm not getting anything remotely resembling video.
Any thoughts on what I might be doing wrong?
Joined: 1/13/2010(UTC) Posts: 5,335  Location: Gold Coast, Australia Was thanked: 4735 time(s) in 1624 post(s)
Does it work in the Studio Monitor app on the same computer?
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
Why don't you use the Larix Broadcaster App and go via SRT. You may even bridge WAN -> LAN which is not possible with NDI natively. In essence as long as you have reception on your iphone you can submit into vmix that can be local/remote or even a complete other country.
Mavik, I'll give that a try.
FWIW, It appears to have been a network issue. Same setup on a different WiFi network and everything worked.
Glad you figured it out. Feel free to test larix broadcaster it might give you a more secure link. You can use SRT LAN -> LAN or WAN -> LAN
NDI
