marek69
#1 Posted : Monday, February 10, 2020 12:34:36 AM(UTC)
marek69
Poland
I have an application that allows me to display graphics via the API. Unfortunately, the animations made in GT do not work, the graphics are displayed without problems (and disappear as I want). Of course, if I display the graphics as an overlay, the animations work. What's the problem?
#2 Posted : Monday, February 10, 2020 1:02:37 AM(UTC)
Animations are triggered by the title being in overlay ( or any function in the title that responds to like a datachange and so )
but if you click the play button of the title input you can see the start animation
There is no problem
marek69
#3 Posted : Tuesday, February 11, 2020 5:15:52 AM(UTC)
marek69
Poland
Sorry but I do not understand...
I have an application to which I paste the code of a given gtzip graphic. The application has its own interface, everything is displayed, replaced etc. in vmix - works. But this does not start the animation.
However, if I manually run the graphic in vmix as an overlay, then of course the animation works.
Similar Topics
GT Designer - Free (Feature Requests)
by PiateZebedee 7/21/2026 9:06:38 AM(UTC)
GT Designer - Stacked Layers (Feature Requests)
by PiateZebedee 7/21/2026 9:03:56 AM(UTC)
GT designer: toggle for animation slo-mo for debugging animations (Feature Requests)
by jip 7/8/2026 11:29:45 PM(UTC)
GT Designer Improvements for Broadcast Graphics and MOS Newsroom Workflows (Feature Requests)
by Seni 3/17/2026 9:56:43 AM(UTC)
GT Designer - ImportPSD - Element Naming (issue) (GT)
by carl.cut4th 11/23/2025 3:33:02 AM(UTC)
Allow custom safe zones in GT Designer Advanced (Feature Requests)
by offroadmediagroup 8/7/2025 6:26:15 AM(UTC)
GT designer interface gets messy when zoomed in (GT)
by TL68 4/2/2025 9:25:23 PM(UTC)
Feature Request GT Designer Advance: changing font for all selected fields (Feature Requests)
by afonia 2/9/2025 9:15:26 PM(UTC)
Anchor point (direction) for Zoom Animation in GT Designer and Mask one layer by another (Feature Requests)
by semenov_nick_1990 11/27/2024 11:30:48 PM(UTC)
Issue with Text TransitionOUT Timing in vMix GT Designer (GT)
by kuuminsh 10/28/2024 11:46:52 PM(UTC)
GT Designer agregar nuevos efectos (Feature Requests)
by Cardozo_joni 9/18/2024 3:29:59 AM(UTC)
One of my works on GT Designer (Showcase)
by adeloche 8/30/2024 12:41:51 AM(UTC)
Support for bounding feature for right aligned text in GT Designer (Feature Requests)
by TL68 7/2/2024 10:26:06 PM(UTC)
Add feature in gt designer many more transition in countinuous (Feature Requests)
by Pawansaini4 6/6/2024 4:17:45 PM(UTC)
GT Designer: Allowing bounding box change its size with animation when data change? (GT)
by minhdowndown 5/2/2024 3:52:17 AM(UTC)
by Turnier 3/25/2024 4:38:21 AM(UTC)
GT designer animation (GT)
by Jimmy Mpoyi 12/21/2023 3:22:05 AM(UTC)
GT Designer Questions and Issues (GT)
by BetrayedByTheGame1996 11/17/2023 2:28:59 AM(UTC)
GT Designer - Font Manager (Feature Requests)
by RSB 6/9/2023 6:52:10 PM(UTC)
Bypass Graphic card check for GT Designer (GT)
by BrixxNatt 1/11/2023 9:43:47 PM(UTC)
GT Designer moving files (GT)
by GBCVideoTD 10/8/2022 4:20:19 PM(UTC)
GT Designer-Auto Follow (Feature Requests)
by tmathews 7/10/2022 2:47:10 PM(UTC)
Colour Binding in GT Designer (Feature Requests)
by Fountain Kamanga 2/17/2022 6:09:03 AM(UTC)
GT DESIGNER UPDATE REQUEST (TEXT RESIZING ON WIDTH ONLY) (Feature Requests)
by MEENO 1/12/2022 4:11:14 AM(UTC)
GT Designer "not a bug" but a wierd feature :-) (Feature Requests)
by Tuomas 11/17/2021 3:10:15 AM(UTC)
GT Designer: Multiple select and edit, and copy/paste properties (Feature Requests)
by ocrtalk 8/26/2021 2:57:54 AM(UTC)
Does Gt designer have the function of a variable size box depending on the length of the text? (GT)
by Xavi137 6/12/2021 7:05:00 AM(UTC)
GT DESIGNER - Batch changes (Feature Requests)
by daveydouble 6/9/2021 11:05:29 PM(UTC)
GT Designer bulk change (GT)
by daveydouble 6/8/2021 11:16:16 PM(UTC)
Collapse groups in GT Designer (Feature Requests)
by Egriswold 4/11/2021 12:18:07 PM(UTC)
