Joined: 9/4/2011(UTC) Posts: 15  Location: South Africa Was thanked: 2 time(s) in 2 post(s)
Hi Martin
I have come across a problem where the cam input video levels go up on the screen as well as the recording, when you open the window to do tweaks to say for instance your pic in pic size. When you close the window the cam level returns to normal. It also happens when you want to tweak one cam level that the other cam's levels go up during the tweak and when the window is closed it returns to "normal" . This is a problem when you are in a live cut situation and you need to do tweaks. Could it be because I am using cheap analog pci capture cards for the test I am running on vMix ? Would getting decklink cards sort this out ??
Regards Barend
Joined: 1/13/2010(UTC) Posts: 5,323  Location: Gold Coast, Australia Was thanked: 4727 time(s) in 1619 post(s)
Can you describe what you mean by "cam input video levels"?
Thanks,
Martin vMix
In short, it gets brighter...
Thanks,
Which windows are you opening to do the tweaks? vMix should just use whatever video input it is given and should not affect the picture quality.
Martin vMix
HI
The issue seems to have resolved it self.... Thanks Martin for a great product keep up the good work!!! Looking forward to the end result ...
