barend
#1 Posted : Wednesday, September 14, 2011 5:55:20 AM(UTC)
barend
Hi Martin
I have come across a problem where the cam input video levels go up on the screen as well as the recording, when you open the window to do tweaks to say for instance your pic in pic size. When you close the window the cam level returns to normal. It also happens when you want to tweak one cam level that the other cam's levels go up during the tweak and when the window is closed it returns to "normal" . This is a problem when you are in a live cut situation and you need to do tweaks. Could it be because I am using cheap analog pci capture cards for the test I am running on vMix ? Would getting decklink cards sort this out ??
Regards
Barend
#2 Posted : Wednesday, September 14, 2011 5:58:07 AM(UTC)
Was thanked: 4659 time(s) in 1606 post(s)
Can you describe what you mean by "cam input video levels"?
Thanks,
barend
#3 Posted : Wednesday, September 14, 2011 11:12:04 AM(UTC)
barend
In short, it gets brighter...
#4 Posted : Wednesday, September 14, 2011 12:07:21 PM(UTC)
Thanks,
Which windows are you opening to do the tweaks?
vMix should just use whatever video input it is given and should not affect the picture quality.
barend
#5 Posted : Thursday, September 15, 2011 5:38:31 AM(UTC)
barend
HI
The issue seems to have resolved it self....
Thanks Martin for a great product keep up the good work!!! Looking forward to the end result ...
Similar Topics
GT load bug ??? (GT)
by przemsi 4/27/2023 7:51:55 PM(UTC)
vMix 23 possible bug ? MIX inputs won't start videos (General Discussion)
by DWAM 6/17/2020 5:04:14 PM(UTC)
Data Change CSV Freezing BUG ? (GT)
by bgbenni 1/6/2020 8:47:32 PM(UTC)
DataSource Json Bug ? -SOLVED (General Discussion)
by doggy 3/2/2018 7:18:08 AM(UTC)
Vmix BUG ? (General Discussion)
by oshern 12/8/2017 5:44:37 AM(UTC)
