bgbenni
#1 Posted : Monday, June 10, 2019 8:09:54 PM(UTC)
bgbenni
Germany
I get from a csv file information for my scoreboards, is it possibly if the data is charging in the csv (scoreboard) that vmix is make a cut or show a new transmission Automatik.
As Exempel csv Information round 1 is change to round 2 now I would like that vmix is Change from cam 1 to cam 2 automatic.
I hope you understanding and maybe someone have a Idee
Thx
Siroki
#2 Posted : Monday, June 10, 2019 8:41:46 PM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
Thx
First I understand you that you wanna transition on data change in csv. Samo kind of a merge transition from Round 1 to Round 2.
Second I understand you wanna make some action when data is changes to switch to another camera angle.
What is right?
bgbenni
#3 Posted : Monday, June 10, 2019 11:37:34 PM(UTC)
bgbenni
Germany
Yes correct, any Idee to do this on vmix?
