 Joined: 5/29/2018(UTC) Posts: 76 Thanks: 25 timesWas thanked: 4 time(s) in 4 post(s)
                I get from a csv file information for my scoreboards, is it possibly if the data is charging in the csv (scoreboard) that vmix is make a cut or show a new transmission Automatik.
 As Exempel csv Information round 1 is change to round 2 now I would like that vmix is Change from cam 1 to cam 2 automatic.
 I hope you understanding and maybe someone have a Idee
 Thx
 Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki BrijegThanks: 8 timesWas thanked: 27 time(s) in 24 post(s)
                Originally Posted by: bgbenni  I get from a csv file information for my scoreboards, is it possibly if the data is charging in the csv (scoreboard) that vmix is make a cut or show a new transmission Automatik.
 Thx
 First I understand you that you wanna transition on data change in csv. Samo kind of a merge transition from Round 1 to Round 2. Second I understand you wanna make some action when data is changes to switch to another camera angle. What is right? |
                Yes correct, any Idee to do this on vmix?  |
