Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
I get from a csv file information for my scoreboards, is it possibly if the data is charging in the csv (scoreboard) that vmix is make a cut or show a new transmission Automatik.
As Exempel csv Information round 1 is change to round 2 now I would like that vmix is Change from cam 1 to cam 2 automatic.
I hope you understanding and maybe someone have a Idee
Thx
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
Originally Posted by: bgbenni  I get from a csv file information for my scoreboards, is it possibly if the data is charging in the csv (scoreboard) that vmix is make a cut or show a new transmission Automatik.
Thx First I understand you that you wanna transition on data change in csv. Samo kind of a merge transition from Round 1 to Round 2. Second I understand you wanna make some action when data is changes to switch to another camera angle. What is right?
Yes correct, any Idee to do this on vmix?
