Slaver
#1 Posted : Monday, June 3, 2019 11:08:34 PM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
Hello Folks,
i found a reproducible phenomenon using the vMix API.
In my basketball setup, i send the scoreboard data (HomePoints, AwayPoints, GameClock, Quarter, ShotClock) directly in to the vMix API over network from another computer. Everytime when i start to send the data into the API, my render time starts up to increase up to 120ms, but just for the tenth of a second. My whole production is starting up to drop frames. The FPS decrease to 38-47 FPS.
The CPU is chilling, just see the attachment.
Bildschirmfoto 2019-06-03 um 14.58.43.png (3,330kb) downloaded 29 time(s).
Maybe admin can help me out?
Best
Marvin
#2 Posted : Monday, June 3, 2019 11:49:39 PM(UTC)
Was thanked: 4721 time(s) in 1617 post(s)
When updating multiple fields, it is important to call the shortcut PauseRender on the title input
and then ResumeRender after updating all the data.
This will result in a single render of all the fields at once, rather than one at a time.
Slaver on 6/4/2019(UTC), stigaard on 5/2/2020(UTC)
stigaard
#3 Posted : Tuesday, June 4, 2019 6:39:26 AM(UTC)
stigaard
Denmark
Martin, how about if you update all fields in one (batch) command via API? Do you still need to use PauseRender and ResumeRender?
#4 Posted : Tuesday, June 4, 2019 12:34:05 PM(UTC)
Yes, a batch command will still be processed the same way without PauseRender/ResumeRender.
Slaver
#5 Posted : Tuesday, June 4, 2019 4:50:27 PM(UTC)
Slaver
Thanks Martin for the quick response.
I am just wondering how to proceed now, because its a scoreboard with two continues running gametimes (Clock and Shotclock). So there is not really a pause in the datafeed, just when there is a timeout or halftime.
Best
Marvin
#6 Posted : Tuesday, June 4, 2019 7:11:07 PM(UTC)
Check to make sure you are not updating fields unless they need to be changed,
then if updating more than one field at a time use the pauserender/resumerender.
Also be sure not to update titles more than 5 times a second (every 200ms) if possible when using older XAML titles.
For newer GT titles, they can be updated much more often without impacting performance.
