vMix API impair Render Time
Thanks: 27 times Was thanked: 8 time(s) in 8 post(s)
Hello Folks, i found a reproducible phenomenon using the vMix API. In my basketball setup, i send the scoreboard data (HomePoints, AwayPoints, GameClock, Quarter, ShotClock) directly in to the vMix API over network from another computer. Everytime when i start to send the data into the API, my render time starts up to increase up to 120ms, but just for the tenth of a second. My whole production is starting up to drop frames. The FPS decrease to 38-47 FPS. The CPU is chilling, just see the attachment.  Bildschirmfoto 2019-06-03 um 14.58.43.png (3,330kb) downloaded 29 time(s).Maybe admin can help me out? Best Marvin
Joined: 1/13/2010(UTC) Posts: 5,316  Location: Gold Coast, Australia Was thanked: 4718 time(s) in 1616 post(s)
When updating multiple fields, it is important to call the shortcut PauseRender on the title input and then ResumeRender after updating all the data.
This will result in a single render of all the fields at once, rather than one at a time.
Martin vMix
Martin, how about if you update all fields in one (batch) command via API? Do you still need to use PauseRender and ResumeRender?
Yes, a batch command will still be processed the same way without PauseRender/ResumeRender.
Thanks Martin for the quick response.
I am just wondering how to proceed now, because its a scoreboard with two continues running gametimes (Clock and Shotclock). So there is not really a pause in the datafeed, just when there is a timeout or halftime.
Best Marvin
Check to make sure you are not updating fields unless they need to be changed, then if updating more than one field at a time use the pauserender/resumerender.
Also be sure not to update titles more than 5 times a second (every 200ms) if possible when using older XAML titles. For newer GT titles, they can be updated much more often without impacting performance.
Martin vMix
