Slaver
#1 Posted : Monday, June 3, 2019 11:08:34 PM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
Hello Folks,
i found a reproducible phenomenon using the vMix API.
In my basketball setup, i send the scoreboard data (HomePoints, AwayPoints, GameClock, Quarter, ShotClock) directly in to the vMix API over network from another computer. Everytime when i start to send the data into the API, my render time starts up to increase up to 120ms, but just for the tenth of a second. My whole production is starting up to drop frames. The FPS decrease to 38-47 FPS.
The CPU is chilling, just see the attachment.
Bildschirmfoto 2019-06-03 um 14.58.43.png (3,330kb) downloaded 29 time(s).
Maybe admin can help me out?
Best
Marvin
#2 Posted : Monday, June 3, 2019 11:49:39 PM(UTC)
When updating multiple fields, it is important to call the shortcut PauseRender on the title input
and then ResumeRender after updating all the data.
This will result in a single render of all the fields at once, rather than one at a time.
Slaver on 6/4/2019(UTC), stigaard on 5/2/2020(UTC)
stigaard
#3 Posted : Tuesday, June 4, 2019 6:39:26 AM(UTC)
stigaard
Denmark
Martin, how about if you update all fields in one (batch) command via API? Do you still need to use PauseRender and ResumeRender?
#4 Posted : Tuesday, June 4, 2019 12:34:05 PM(UTC)
Yes, a batch command will still be processed the same way without PauseRender/ResumeRender.
Slaver
#5 Posted : Tuesday, June 4, 2019 4:50:27 PM(UTC)
Slaver
Thanks Martin for the quick response.
I am just wondering how to proceed now, because its a scoreboard with two continues running gametimes (Clock and Shotclock). So there is not really a pause in the datafeed, just when there is a timeout or halftime.
Best
Marvin
#6 Posted : Tuesday, June 4, 2019 7:11:07 PM(UTC)
Check to make sure you are not updating fields unless they need to be changed,
then if updating more than one field at a time use the pauserender/resumerender.
Also be sure not to update titles more than 5 times a second (every 200ms) if possible when using older XAML titles.
For newer GT titles, they can be updated much more often without impacting performance.
