Joined: 6/2/2012(UTC) Posts: 103  Location: Germany Thanks: 13 times Was thanked: 10 time(s) in 9 post(s)
Is there a way to use an animated background or foreground in virtual sets, something like an avi with transparency?
I found the solution for animated background in virtual sets, just add dynamic="True" to the config.xml. Something else: The preview picture in the zoom editor isn't the same as the reality, please have a look. Video DescriptionVirtualSet.zip
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
All graphics used in the virtual set config.xml file must be in a 16:9 aspect ratio otherwise they will look incorrect in the preview.
Martin vMix
Thanks, Martin this fixed it. But I have still two problems: 1. The second camera thumbnail shows not the correct result 2. After adding a new virtual set, the crop settings from the config.xml aren't loaded VirtualSet2.zip
