cutter07
#1 Posted : Thursday, January 30, 2014 11:28:15 AM(UTC)
cutter07
Is there a way to use an animated background or foreground in virtual sets, something like an avi with transparency?
cutter07
#2 Posted : Sunday, February 2, 2014 9:27:51 AM(UTC)
cutter07
I found the solution for animated background in virtual sets, just add dynamic="True" to the config.xml.
Something else:
The preview picture in the zoom editor isn't the same as the reality, please have a look.
Video Description
VirtualSet.zip
#3 Posted : Sunday, February 2, 2014 9:45:54 AM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
All graphics used in the virtual set config.xml file must be in a 16:9 aspect ratio otherwise
they will look incorrect in the preview.
cutter07
#4 Posted : Sunday, February 2, 2014 6:06:17 PM(UTC)
cutter07
Thanks, Martin this fixed it.
But I have still two problems:
1. The second camera thumbnail shows not the correct result
2. After adding a new virtual set, the crop settings from the config.xml aren't loaded
VirtualSet2.zip
Similar Topics
SelectIndex (Virtual Set) (General Discussion)
by LeChatFantome 11/23/2025 1:46:47 PM(UTC)
Web-based vMix Virtual Set Builder (3rd Party Software and Development)
by Onlinegill 11/18/2025 3:06:35 PM(UTC)
Prevent dragging layers in virtual set setup? (General Discussion)
by TBacker 8/22/2025 6:34:22 AM(UTC)
Bug: virtual set setup UI regression (FIXED) (Beta Discussion)
by ryxyz 1/2/2025 6:01:54 AM(UTC)
Virtual set upgrade (Feature Requests)
by zxa@centrum.cz 11/8/2024 8:32:31 PM(UTC)
Lock Inputs in Virtual Set (Feature Requests)
by ShaneAnto201 10/26/2023 9:16:54 AM(UTC)
Shortcut/API funktion for setting the zoom speed in virtual sets! (Feature Requests)
by Gunnar 2/3/2023 8:26:31 PM(UTC)
Editing 2d Layouts/Virtual Sets? (General Discussion)
by Vproductions 11/16/2022 5:15:23 AM(UTC)
Scripting for Virtual sets (General Discussion)
by Paul Camino 9/14/2022 8:16:49 AM(UTC)
Adding a cropped video to Virtual Set (General Discussion)
by robaanrobio 6/1/2022 11:18:04 PM(UTC)
Activators and Monitor of Selected index in a virtual set input (General Discussion)
by richardnottv 6/1/2022 9:54:11 AM(UTC)
Save vMix preset (bundle) - Virtual sets offline problem (General Discussion)
by Bikeroo 4/28/2022 4:56:55 AM(UTC)
Titles, Inputs, and Virtual Sets (General Discussion)
by jkhouw 4/28/2022 2:43:55 AM(UTC)
Maximum resolution for Virtual Sets (General Discussion)
by udo.schneider 3/21/2022 8:12:07 AM(UTC)
NEED HERO Almost showtime, crazy 2 shot bleed over in virtual set (General Discussion)
by ugbandtulsa 2/17/2022 7:01:15 AM(UTC)
Quick Virtual Set creation (3rd Party Software and Development)
by doggy 1/9/2022 9:13:30 PM(UTC)
Perspective problem with a virtual set - Problema perspectiva con un set virtual (General Discussion)
by mamomo 1/5/2022 9:56:22 AM(UTC)
Virtual Sets, Overlays & Layers (General Discussion)
by shampton 10/29/2021 4:45:51 AM(UTC)
Bringing a virtual set into a virtual set (General Discussion)
by themann00 9/21/2021 11:00:40 PM(UTC)
Changing angles in virtual set (General Discussion)
by Narcogen 9/21/2021 6:33:22 AM(UTC)
New Virtual Sets available (3rd Party Software and Development)
by jcuellars 9/14/2021 10:17:48 AM(UTC)
Glitch Line on Custom Virtual Set (General Discussion)
by Revocayne 8/19/2021 6:33:20 PM(UTC)
Virtual Set copys (General Discussion)
by Jesus RM 8/3/2021 12:50:24 AM(UTC)
Can not add NDI layer to a virtual set (NDI)
by Vadim 8/2/2021 10:58:33 PM(UTC)
affecting virtual sets in preview..changing inputs via a midi controller (General Discussion)
by durtball 7/29/2021 12:24:33 AM(UTC)
My new tool for creating vMix Virtual Sets for grid views (General Discussion)
by john-at-heretorecord 7/16/2021 12:59:14 AM(UTC)
Support more "camera zooms" in the Virtual Set input (Feature Requests)
by john-at-heretorecord 7/16/2021 12:35:58 AM(UTC)
Using Panel Builder to Virtual Sets Inputs (3rd Party Software and Development)
by VideoE 7/13/2021 2:14:10 PM(UTC)
How to save virtual set (General Discussion)
by DFNB 7/9/2021 3:36:01 PM(UTC)
Sharing my virtual set desings. (Showcase)
by jcuellars 7/1/2021 2:52:17 AM(UTC)
