Franck
#1 Posted : Sunday, January 13, 2019 7:33:25 AM(UTC)
Franck
Hi alls,
For radio project transmitting video with low SR, I need a perfect TS encoding.
My question is in title.
VLC is not perfect, fffpeg is better but exist an other software under windows???
Regards
#2 Posted : Sunday, January 13, 2019 7:25:29 PM(UTC)
I don't think so. I'd say most (not to say all) of the free or affordable software encoders use FFMPEG.
You can go for hardware encoders though: cheap ones still use FFMPEG btw... Very good contribution encoders like ATEME or Harmonic which support TS usually cost several thousand euros/dollars.
Again FFMPEG is the best solution imho...
Guillaume
Franck
#3 Posted : Sunday, January 13, 2019 9:50:33 PM(UTC)
Franck
Hi Guillaume,
Message is clear.. also, I have need to use CBR, and ffmpeg can created it.
also I have to make an effort to use the command lines
#4 Posted : Monday, January 14, 2019 2:37:17 AM(UTC)
FFMPEG can do strict CBR if you ask him gently! ;o)
