what is best software to generate TS stream in CBR behind VMIX
Hi alls, For radio project transmitting video with low SR, I need a perfect TS encoding. My question is in title. VLC is not perfect, fffpeg is better but exist an other software under windows??? Regards
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 795 time(s) in 589 post(s)
I don't think so. I'd say most (not to say all) of the free or affordable software encoders use FFMPEG. You can go for hardware encoders though: cheap ones still use FFMPEG btw... Very good contribution encoders like ATEME or Harmonic which support TS usually cost several thousand euros/dollars.
Again FFMPEG is the best solution imho...
Guillaume
Hi Guillaume, Message is clear.. also, I have need to use CBR, and ffmpeg can created it. also I have to make an effort to use the command lines @++
FFMPEG can do strict CBR if you ask him gently! ;o)
