Element III
#1 Posted : Saturday, December 15, 2018 6:03:31 AM(UTC)
Element III
Hello guys i have some ideas for vmix shortcut.
First for the shortcut it could be perfect if we can set up shortcut like tricaster workflow:
X1-X2-X3-X4-X5-X6-X7-X8-X9-X..... (multiviewoverlay1 source 1,2,3,4...)
Y1-Y2-Y3-Y4-Y5-Y6-Y7-Y8-Y9-Y..... (multiviewoverlay2 source 1,2,3,4...)
Z1-Z2-Z3-Z4-Z5-Z6-Z7-Z8-Z9-Z..... (multiviewoverlay3 source 1,2,3,4...)
A1-A2-A3-A4-A5 ... (scene 1,2,3... in program)
B1-B2-B3-B4-B5 ... (scene 1,2,3... in preview)
Key Ax set scene x in program
Key Bx set scene x in preview
Key Xx set source x in the multiview overlay 1
Key Yx set source x in the multiview overlay 2
Key Zx set source x in the multiview overlay 3
Exemple:
If
key B1 is press set scene 1 in preview
key X, Y, Z light on when the source in on the right multiview overlay
(if the source 4 is in the multiview overlay 1 the X4 key light on other off)
(if the source 1 is in the multiview overlay 2 the Y1 key light on other off)
If
key X1 is press
then
setmultiviewoverlay 1 = source 1
If
key Y4 is press
then
setmultiviewoverlay 2 = source 4
If you have some question let'go haha
Thx
Morgan
#2 Posted : Saturday, December 15, 2018 7:05:02 AM(UTC)
Hi
your FR looks like those about "modifiers", that is 2 steps shortcuts.
I have demoed a way to achieve the same results using vMix as is
Check this : https://forums.vmix.com/...-Akai-APC-Mini-with-vMix
I have also submitted a FR for "dynamic inputs and functions for shortcuts" you might be interested by as an alternative to bring more flexibility when using shortcuts
https://forums.vmix.com/...-Functions-for-Shortcuts
Feel free to +1 if you like the idea
Guillaume
Element III
#3 Posted : Saturday, December 15, 2018 7:30:54 AM(UTC)
Element III
Yes thx for your answer the things is that i already doing shortcut for each scene but its take too many key on the pad i would love to have a dynamics shortcuts who change action with another action key i did a gif of what i thought
Gif
#4 Posted : Saturday, December 15, 2018 4:24:59 PM(UTC)
C'est exactement l'objet de ma feature request "Dynamic Inputs & Functions" qui par ailleurs propose une méthode d'implémentation réalisable pour vMix et a déjà pas mal de +1.
Element III
#5 Posted : Sunday, December 16, 2018 3:27:26 AM(UTC)
Element III
Yes j'avais pas encore vu mais effectivement ca serait le top je vais +1 aussi du coup ;) merci
Similar Topics
Shortcuts Enabling/Disabling Multicord Sources (Feature Requests)
by Alex Stearns 6/3/2026 1:31:24 AM(UTC)
Production Clock Shortcuts (Feature Requests)
by Alex Stearns 6/3/2026 1:24:28 AM(UTC)
Shortcut Assignment WEB GUI (Feature Requests)
by DJShaggyd 5/16/2026 7:02:14 PM(UTC)
Is the resetinput-shortcut the same as the reload command on a GT-title input? (General Discussion)
by TL68 4/29/2026 9:56:09 PM(UTC)
Shortcuts - Dropdown menu for Script selection (Feature Requests)
by mikesg 4/8/2026 3:50:45 AM(UTC)
Title, DataSource and shortcut (GT)
by blidkvist 3/20/2026 3:23:18 AM(UTC)
What shortcut to update vMix Social content? (General Discussion)
by Podcast Bob 3/17/2026 10:22:11 PM(UTC)
Shortcut ReplayDeleteSelectedEvent not working (Instant Replay)
by InstantReplayGO 3/14/2026 5:40:45 AM(UTC)
Shortcuts for X-Keys (Hardware Compatibility)
by WRONBA 3/12/2026 10:50:42 PM(UTC)
Replay API + Request for new shortcuts (Feature Requests)
by aircooled76@gmail.com 2/1/2026 5:50:22 PM(UTC)
Shortcut to change a layer ? (General Discussion)
by xenaton 1/23/2026 12:07:54 AM(UTC)
How to increase / decrease audio volume step by step using keyboard shortcuts in vMix 29? (General Discussion)
by medesan 1/15/2026 5:45:35 AM(UTC)
Fade function on ReplaySwapChannels shortcut (Instant replay) (Feature Requests)
by elmars@sportacentrs.com 1/14/2026 6:15:34 PM(UTC)
Auto Script Start doesn't work from desktop shortcut, only by loading inside vMix (General Discussion)
by fgolman 12/7/2025 9:22:26 AM(UTC)
Shortcut for Luma Key (Feature Requests)
by ktr13 11/25/2025 5:25:55 AM(UTC)
“Continue playback after events” shortcut (Feature Requests)
by zumine 11/24/2025 12:47:50 AM(UTC)
Shortcut support for vMixcall input configuration (Feature Requests)
by BBCDaveF 11/21/2025 5:54:34 AM(UTC)
Shortcut to change color of borders (Feature Requests)
by knbPixels 10/15/2025 1:46:56 AM(UTC)
Reply white box shortcut toggle (General Discussion)
by Ed789 9/16/2025 2:36:30 AM(UTC)
Lost all my shortcuts (General Discussion)
by SpaceAge 9/9/2025 9:26:48 AM(UTC)
Web Controller - Shortcut - Callback Function (General Discussion)
by emZi 8/29/2025 3:12:09 AM(UTC)
Shortcut Key for OMT Preview Mode (Feature Requests)
by moocowsheep 8/21/2025 8:57:14 AM(UTC)
Suggestion vMix Replay v29 NewShortcuts (Feature Requests)
by InstantReplayGO 8/19/2025 5:57:14 AM(UTC)
Thank for new vMix Replay Shortcuts v29 (Beta Discussion)
by InstantReplayGO 8/17/2025 12:02:44 PM(UTC)
GO Action shortcut does not handle moved inputs (FIXED) (Beta Discussion)
by ryxyz 8/17/2025 12:08:52 AM(UTC)
"Set Stinger" Shortcuts not working (General Discussion)
by knbPixels 5/2/2025 11:30:11 AM(UTC)
Overlay Shortcuts (General Discussion)
by Cyberkorr 4/27/2025 7:36:36 AM(UTC)
Add new vMix Replay shortcuts (Feature Requests)
by InstantReplayGO 4/26/2025 3:12:21 AM(UTC)
Shortcut and API command for "Change input" (Feature Requests)
by kirik 4/18/2025 3:41:38 AM(UTC)
Toggle Between Different Mixes with a Single Shortcut (Feature Requests)
by mataohave 4/10/2025 10:29:33 PM(UTC)
