Instant Replay
Shortcut ReplayDeleteSelectedEvent not working
Joined: 4/26/2025(UTC) Posts: 23   Location: São Paulo Was thanked: 8 time(s) in 3 post(s)
Hi everyone, in some tests I noticed that the ReplayDeleteSelectedEvent function removes the selected event (clip), but when I select 2 or more events it only removes the first one with the ID in ascending order, unlike when you select 2 or more events and right-click and select DELETE, which opens a popup window asking if you want to delete X selected events.
I would like to request that the correction for this ReplayDeleteSelectedEvent function be included in the v29 update roadmap.
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: InstantReplayGO  Hi everyone, in some tests I noticed that the ReplayDeleteSelectedEvent function removes the selected event (clip), but when I select 2 or more events it only removes the first one with the ID in ascending order, unlike when you select 2 or more events and right-click and select DELETE, which opens a popup window asking if you want to delete X selected events.
I would like to request that the correction for this ReplayDeleteSelectedEvent function be included in the v29 update roadmap. its called ...SelectedEvent and not ...SelectedEvent SAlso see https://forums.vmix.com/posts/t1...5-Shortcut-Delete-ReplayIMO if you already selecting multiple events (mouse) one might as well do the right click
Originally Posted by: doggy  Originally Posted by: InstantReplayGO  Hi everyone, in some tests I noticed that the ReplayDeleteSelectedEvent function removes the selected event (clip), but when I select 2 or more events it only removes the first one with the ID in ascending order, unlike when you select 2 or more events and right-click and select DELETE, which opens a popup window asking if you want to delete X selected events.
I would like to request that the correction for this ReplayDeleteSelectedEvent function be included in the v29 update roadmap. its called ...SelectedEvent and not ...SelectedEvent SAlso see https://forums.vmix.com/posts/t1...5-Shortcut-Delete-ReplayIMO if you already selecting multiple events (mouse) one might as well do the right click Hi Doggy are you good? Regarding the post from 8 years ago, I'm curious that something with so many likes and comments still isn't working. About selecting all clips, I used a shortcut, not the mouse, my friend. I think you forgot to check that we have a `ReplaySelectAllEvents` in the shortcut list. The idea is to follow the logic using an external control: select everything and delete the selected ones, in this case, "All". And the shortcut I mentioned doesn't have "Event"s; I think you saw it wrong.
No I did not forget about the SelectAll because you wrote "select 2 or more events" which is not all !
No I did not forget about the SelectAll because you wrote "select 2 or more events" which is not all ! I understand what you meant; in vMix it's confusing, what should be Clip = events and what should be playlist = event. But the reference I made was that SelectAll selects all clips in the playlist/TabX, and with all selected, DeleteSelected should delete them all at once. In the 8 years since the request in the post you sent me and they haven't resolved it, I believe it's not that important for something so simple. Let's wait and see.
Instant Replay
