InstantReplayGO
#1 Posted : Saturday, March 14, 2026 5:40:45 AM(UTC)
InstantReplayGO
Brazil
Was thanked: 8 time(s) in 3 post(s)
Hi everyone, in some tests I noticed that the ReplayDeleteSelectedEvent function removes the selected event (clip), but when I select 2 or more events it only removes the first one with the ID in ascending order, unlike when you select 2 or more events and right-click and select DELETE, which opens a popup window asking if you want to delete X selected events.
I would like to request that the correction for this ReplayDeleteSelectedEvent function be included in the v29 update roadmap.
#2 Posted : Saturday, March 14, 2026 6:39:10 AM(UTC)
its called ...SelectedEvent and not ...SelectedEventS
Also see https://forums.vmix.com/posts/t1...5-Shortcut-Delete-Replay
IMO if you already selecting multiple events (mouse) one might as well do the right click
InstantReplayGO
#3 Posted : Saturday, March 14, 2026 9:29:19 AM(UTC)
InstantReplayGO
Brazil
Hi Doggy are you good?
Regarding the post from 8 years ago, I'm curious that something with so many likes and comments still isn't working.
About selecting all clips, I used a shortcut, not the mouse, my friend. I think you forgot to check that we have a `ReplaySelectAllEvents` in the shortcut list. The idea is to follow the logic using an external control: select everything and delete the selected ones, in this case, "All".
And the shortcut I mentioned doesn't have "Event"s; I think you saw it wrong.
#4 Posted : Saturday, March 14, 2026 11:10:54 AM(UTC)
No I did not forget about the SelectAll because you wrote "select 2 or more events" which is not all !
InstantReplayGO
#5 Posted : Sunday, March 15, 2026 3:46:34 AM(UTC)
InstantReplayGO
Brazil
I understand what you meant; in vMix it's confusing, what should be Clip = events and what should be playlist = event. But the reference I made was that SelectAll selects all clips in the playlist/TabX, and with all selected, DeleteSelected should delete them all at once. In the 8 years since the request in the post you sent me and they haven't resolved it, I believe it's not that important for something so simple.
Let's wait and see.
